Upload_max_filesize
epiz_30219194
The uploaded file exceeds the upload_max_filesize directive in php.ini.
I get this error when i try to upload a theme or a plugin from zip
If theme or plugin is more than 10mb, it is better to extract files locally then upload via ftp
idk how to do that :confused:
Unzip the file on your computer, then upload the resulting folder to your website.
i tried it,but it resulted a serial error on wordpress
Not if you do it correctly. Unzip the file on your computer, and upload the folder to the “Plugins” folder using FTP.
yeah, i did the same, with filezilla.
it works finally!! tysm
