I installed WordPress on my site but it was not there so I tried to uninstall it but it gave error connection lost so I took things on my hand and delete the place where it was going to be deleted but after that time it is just saying “Directory Listing” Please Help. Here is my domain animedimension.cf
Hi,
In installing wordpress to your main site.
Install it on the main directory.
Make sure on your softaculous installation the “In Directory” field is left blank.
It worked after installing WordPress again it got fixed but I lost my SSL certificate
@Dratro
you did not lose the cert, but you have mixed content
Please make sure your website is fully configured to use HTTPS URLs. If your website supports HTTPS, it should use HTTPS
If you use a service like Cloudflare’s HTTPS rewrites, please disable it and set your WordPress Website URL correctly instead.
If you want to force HTTPS on a WordPress site, make sure you update your Website URL in the WordPress settings first.
without www in your case
