ftp is running. But this time the website loads extremely late
Info: IS ALL ONLINE
Hi,
I tried reimporting / re-adding the ssl cert, however SSL still seems to be failing.
domain - rem09.rf.gd
rem09.rf.gd resolves to 185.27.134.98
Server Type: nginx
No SSL certificates were found on rem09.rf.gd. Make sure that the name resolves to the correct server and that the SSL port (default is 443) is open on your server's firewall.```
Please create a new topic as the SSL problem here is solved.
Thanks.
Is not solved
Can please help to reopen the original post I had created?
No, because you created that during the issue. Now its solved (supposedly, some say its working) so you will need to create a new one.
Thanks.
Yes
ok, will create a new post. Or do you mean create a new certificate?
Can you move this piece f topic to another topic?
A new post in the forum
FYI @Greenreader9 Iāve been busy with confirming this original issue is indeed closed and had assumed mine was unrelated and opened another thread. However, in light of the following:
- My SSL issue started after this post was considered āresolvedā.
- @aKEtyPhoās identical SSL issue.
- Your deduction that my situation is ākind of weirdā (in my thread).
Perhaps we cannot confirm yet that this postās issue is fully resolved? @Admin FYI
Linking mine here as well for others to find:
Linking another seemingly identical SSL issue:
@Admin can we please get your opinion on the matter? Iām patiently waiting but havenāt heard from you in awhile .
PS found a small difference between my two free accounts that have SSL working and the one that keeps returning ERR_SSL_PROTOCOL_ERROR:
- Working account are on hosting volume vol10_2
- New failing account is on hosting volume vol16_2
Maybe has nothing to do with it, just throwing in whatever information I can find
Try justā¦ waiting
@OverloadedTech I donāt mind waiting, but normally someone in a position to fix needs to first be aware of a problem and acknowledge they are working to fix it otherwise youād be waiting quite a long timeā¦
