my website http://upkkaguitm.infinityfreeapp.com/
(1/1) InvalidArgumentException
View [pages.index] not found.
in FileViewFinder.php line 137
My file structure for index.blade.php
|-- lsapp
|-- app
|-- bootstrap
|-- config
|-- database
|-- note_modules
|-- resources
|-- assets
|-- lang
|-- views
|-- index.blade.php
|-- routes
|-- storage
|-- tests
|-- vendor
|-- htdocs
|-- css
|-- icon
|-- js
|-- vendor
|-- storage
Laravel Version 5.4
Php Version 5.6.
In my localhost, everything is fine.
KangJL
November 6, 2020, 5:13am
#2
There is no index.blade.php
KangJL
November 6, 2020, 5:17am
#3
Move your Files to htdocs Directory
|-- htdocs
|-- css
|-- icon
|-- js
|-- vendor
|-- storage
|-- lsapp
|-- app
|-- bootstrap
|-- config
|-- database
|-- note_modules
|-- resources
|-- assets
|-- lang
|-- views
|-- index.blade.php
|-- routes
|-- storage
|-- tests
|-- vendor
if http://upkkaguitm.infinityfreeapp.com/lsapp/resources/views/ this is your correct directory . try to re-upload index.blade.php
manually .
this is the uploading mistakes ! (May be internet issue )
Thanks !
yes. the correct path. im using laravel 5.4
i have upload it. still the same. i also put it outside of pages folder. still the same.
Admin
November 10, 2020, 3:48pm
#8
So which application is broken exactly? The installation on http://upkkaguitm.infinityfreeapp.com/lsapp/public , the one on http://upkkaguitm.infinityfreeapp.com/public or the one on http://upkkaguitm.infinityfreeapp.com ? I’m going to assume it’s the first one, because it’s the only one which has a complete Laravel installation.
That one crashes because you’ve precompiled the config on your own computer with the wrong paths. This crashes your application. If you remove the PHP files in htdocs/lsapp/bootstrap/cache
, it should work.
system
Closed
November 25, 2020, 3:48pm
#9
