Webpages don't display on the web
epiz_27993767 (espagnolpratique.rf.gd)
Error Message 404
All the files are uploaded (I can check that in the File manager and in the ftp client) BUT ON THE WEB I RECEIVE AN 404 ERROR MESSAGE, and the files do not display
(This occur only with your server : In other all displays correctly)
Hi and welcome to forum.
Can you please tell us which files do you have this issue with?
regards,
I had this problem too. You have to clear your web data (not just cache).
Your web browser will then show the files correctly.
If not, then try re-uploading the files.
Also check if you set up any redirects, as you could be directing the web page to a 404 (stranger things have happened).
I had that too I just waited 12 hours and it’s good.
Yes, it seems that this occured… the day after, it seems that the server finally found my files and agreed to display them …
Or probably your browser cache did.
Usually a simple way to bypass the browser’s cache is to test the website using an anonymous session.
Just open a “New incognito window” and test the site.
  • Google Chrome: Ctrl+Shift+N
  • Mozilla Firefox: Ctrl+Shift+P
