Website is loading slow and GT METRIX says remove the following redirects if possible
Hi folks,
I am in deep trouble ,my site is loading very very slow that its taking 20s to load and when checked on gtmetrix its report said that i have too many redirects which are to be minimized.
Please help what can i do in this case -
possible:
https://sync.adaptv.advertising.com/sync?rUrl=https%3A%2F%2Fads.stickyadstv.com%2Fuser-registering%3FdataProviderId%3D449%26userId%3D{uid}
https://c1.adform.net/serving/cookie/match/?party=18
https://c1.adform.net/serving/cookie/match/?CC=1&party=18
Remove the following redirect chain if possible:
https://id5-sync.com/c/111/0/0/9/1.gif
https://public-prod-dspcookiematching.dmxleo.com/dspreplyidfive?id5id=FEddy4SGfpdPEw8t3qdR_fWPIIs4Sdji4b26rDpl72Q&replypath=https%3A%2F%2Fid5-sync.com%2Fa%2F111%2F111%2F8%2F2%2Fgif%2FFEddy4SGfpdPEw8t3qdR_fWPIIs4Sdji4b26rDpl72Q
https://id5-sync.com/a/111/111/8/2/gif/FEddy4SGfpdPEw8t3qdR_fWPIIs4Sdji4b26rDpl72Q
https://id5-sync.com/c/111/2/1580405652108381242/7/3.gif
https://ads.creative-serving.com/id5_cm?callback=https%3A%2F%2Fid5-sync.com%2Fc%2F111%2F101%2F[UID]%2F6%2F4.gif
https://ads.creative-serving.com/ul_cb/id5_cm?callback=https%3A%2F%2Fid5-sync.com%2Fc%2F111%2F101%2F[UID]%2F6%2F4.gif
https://id5-sync.com/c/111/101/a47a3274-1690-4d88-80bd-623a7d3b73ea/6/4.gif
https://id5-sync.com/c/111/102/6520556481881801985/5/5.gif
https://sync.adotmob.com/cookie/id5?r=https%3A%2F%2Fid5-sync.com%2Fc%2F111%2F106%2F{amob_user_id}%2F4%2F6.gif
https://id5-sync.com/c/111/106/024720051dd1b59e0282b05d/4/6.gif
https://id5-sync.com/k/18/0.gif
https://loadus.exelator.com/load/?p=1082&g=204&j=0
There were too many more but the maximum words limit got exceeded that’s why i could not put all the redirects here
@Palbros said:
Hi folks,
possible:
https://ads.stickyadstv.com/user-registering?dataProviderId=449&userId=6482127160714997688
https://cm.g.doubleclick.net/pixel?google_nid=stickyxchange_dbm&google_cm=&google_sc
https://cm.g.doubleclick.net/pixel?google_nid=stickyxchange_dbm&google_cm=&google_sc=&google_tc=
https://ads.stickyadstv.com/user-registering?dataProviderId=141&userId=CAESEKSvrmAu3pNdShvXon831ZQ&google_cver=1
https://match.adsrvr.org/track/cmf/generic?ttd_pid=stickyads&ttd_tpi=1
https://ads.stickyadstv.com/user-registering?dataProviderId=208&userId=4c0ca03d-97fe-4978-8db9-99a44a43cd18
https://sync-tm.everesttech.net/upi/pid/wGbQAlJJ?redir=https%3A%2F%2Fads.stickyadstv.com%2Fuser-registering%3FdataProviderId%3D187%26userId%3D%24{TM_USER_ID}
https://ads.stickyadstv.com/user-registering?dataProviderId=187&userId=W2lM1gAAAIQEMxCq
https://ib.adnxs.com/getuid?https%3A%2F%2Fads.stickyadstv.com%2Fuser-registering%3FdataProviderId%3D209%26userId%3D$UID
https://ads.stickyadstv.com/user-registering?dataProviderId=209&userId=1580405652108381242
https://ad.turn.com/r/cs?pid=34
https://ads.stickyadstv.com/user-registering?dataProviderId=147&userId=4598635838339693890
https://sync.mathtag.com/sync/img?mt_exid=44&redir=https%3A%2F%2Fads.stickyadstv.com%2Fuser-registering%3FdataProviderId%3D183%26userId%3D[MM_UUID]
https://sync.mathtag.com/sync/img?mt_exid=44&redir=https%3A%2F%2Fads.stickyadstv.com%2Fuser-registering%3FdataProviderId%3D183%26userId%3D[MM_UUID]&mm_bnc&mm_bct
https://ads.stickyadstv.com/user-registering?dataProviderId=183&userId=4a515b69-46c6-4600-92da-56f879989716
https://ads.stickyadstv.com/user-registering?dataProviderId=189&userId=8609860160320532864
https://x.bidswitch.net/sync?ssp=stickyads
https://id5-sync.com/i/111/9.gif
https://secure.adnxs.com/getuid?https://id5-sync.com/c/111/2/$UID/7/3.gif
https://rtb-csync.smartadserver.com/redir/?partnerid=111&partneruserid=3737669618283368&redirurl=https%3A%2F%2Fid5-sync.com%2Fc%2F111%2F102%2FSMART_USER_ID%2F5%2F5.gif
https://cookie-matching.mediarithmics.com/v1/get_user_agent_id?dom_token=id517
https://load77.exelator.com/pixel.gif
Hi,
Before I answer you, this is not the web server problems, it’s your website.
You can minimize redirect chain by stop forcing https on your site,
For example:
http://domain.tld
https://domain.tld
Also you have ads on your site that affects your website performance
Most of those redirects look like they are advertisement code. Ad codes can redirect a lot of times, but most ad code is good enough they can do that without blocking the regular web content. In short: it’s not a problem and you can’t change it (without removing the ads code, of course).
Maybe some people here can provide more useful performance recommendations, but it would help a lot if you could post your website URL and/or the GTMetrix results here. It’s hard to suggest optimizations for a particular page if you don’t know what that page is.
https://drive.google.com/open?id=1qmyzLcqLFI526Jp9Fh9q7P5hQGZ391np
https://drive.google.com/open?id=1WFtTo_X-G-5TIqpkGTUChWAq94osSlG7
https://drive.google.com/open?id=1mqpN8WF6DQsu-aOUCeUyoQ01XOWasmzo
https://drive.google.com/open?id=1YyL7heo2DdOomYMvMacCiNbaji8KLTbZ
Hi enclosed above are the gtmetrix scores, please also suggest if the ads are causing this much trouble that i need to remove. For your information i m just using dailymotion 1 widget and 1 amazon widget.
The scores don’t tell anything if you can’t expand them and check the results against the actual web page.
Again, can you please post your website URL and/or the GTMetrix results URL here? And not just screenshots and your own interpretations?
Https://www.palbrosinfotainment.ml
https://gtmetrix.com/reports/www.palbrosinfotainment.ml/mJDf5YV7
Please check now amd suggest i would be very thankful to you.
I checked the results but all the issues seem to be caused by the ad networks. There isn’t really anything you can do to change that, except for not using ads anymore. Fortunately, ad codes are loaded in non-blocking, so your website will still appear fast to your visitors.
GTMetrix can be useful to help optimize page load speed. But all they do is provide recommendations. If you don’t score a perfect A on page speed, that doesn’t mean your website is slow or poorly optimized. As with all recommendations, you need to check for yourself what you want to do with them.
