life87
July 30, 2022, 11:39am
1
Verbindung zum Server fehlgeschlagen: No such file or directory
I have an index.php
Status is green
see photos…
Thx for your help.
That looks like an error generated by your code, not InfinityFree. I can confirm this by visiting the index.PHP and login.PHP files on your website.
Please check your code for any errors, and that is where this error will be.
Admin
July 31, 2022, 7:43am
5
As you can see in this article, the error is caused by using localhost
as your database hostname. The correct database hostname looks like sqlXXX.epizy.com (where XXX are three numbers), and can be found either in the client area or in the control panel.
Many websites use MySQL databases to store information and settings. However, there are some reasons why the connection to the database may fail. This article describes some commonly seen error messages when connecting to a database, as well as some general tips to keep in mind when setting up a database connection.
Common Error Messages
Using MySQL is great, but the error message returned if there is an issue logging in to your database can be quite confusing. Here are some commonly seen erro…
system
Closed
August 7, 2022, 7:43am
6
