I have uploaded my files via online file manager. I have also created the database. I am not able to access my website via browser. what is wrong?
nevertheless I did not find the install script mentioned in getting started. I don’t know if this is necessary since I did not use any of the tools mentioned for development. I just uploaded my files and folders into the htdocs files.
I am a bit confused. This has been over 2 weeks. can anyone ?
First of All you need to describe your error and whenever you choose hosting support category, you are supposed to fill out all the detailed information that is asked you there. Remember this from future.
As I can see, The website is reachable and working correctly
*The website is showing infinity free’s default page. You can remove it by deleting index2.html from your domain’s htdocs folder.
The website is working fine from here as well. The big question is of course, why doesn’t it work for you?
Could you please check if you can access your website from another device or another network? It’s possible that some overzealous virus scanner or network administrator is blocking access to our servers.
Below are the screenshots. I want to add that I have also tried holalalala.epizy.com/pages/Home.php. I got the same results, even if I move all files and folders out of the holalalala folder.
You don’t need to worry… Your account is up, and your website is working fine now. Try clearing your cache and cookies and try using it from another browser or another device. If the problem still persists, feel free to reply back
alccbxza.epizy.com/pages/Home.php or alccbxza.epizy.com/holalalala/pages/Home.php
or www.holalalala.epiz.com/pages/Home.php or www.holalalala.epiz.com/holalalala/pages/Home.php
Wail Please, Let me check all the links… Could you please write them in regular format, so that I can check them by clicking? (Not in a Quoted Format?)
You could see the possible reason for your suspension of your account in your account Home Page - Login to your account - InfinityFree.
Then accordingly
It is from the same account. the domain you mentioned, I got it from cpanel. see screenshot. I have not found any information on it. maybe it is dependent on the holalalala.epizy. They are both using this account epiz_23421631
