When i type my domain it says on window lets make something awsome Your account is all set up, it’s time to build your website!
What to do now?
Hi
and welcome to the forum
the template you saw exists for a reason and you should have filled it up when creating this topic
what is your domain or free subdomain?
you need to create your own website or upload files to the appropriate folder
It might be showing index2.html file.
If you are new at infinity free, then you are on a right place. Infinity Free is the best free hosting providers in the world. It ranks #1 in Google analytics. So to get started:
Go-to your cPanel.
There you might see Softaculous App Installer. There you can install any software in 3-4 clicks. It is as simple.
If you need any help further, feel free to reply
