i have created a website in infinityFree. but the matter is not working my website. my all subdomains working perfectly . i did understand what is the problem . I have been using this website for several days. But the domain is no longer available today. i don’t know why my sub-domain only working perfectly ??!!
My domain is provided Godaddy, so i contacted them to solve, after they check it , say that
“contact your hosting support team , this is the problem of your hosting provider”
i have removed and re-added my main Domain, but website still not working… Its worked well, my website working well All thanks dedicated to@anon53753884@anon19508339@KangJL
Admin is himself busy with real life issues, If he was available for helping everyone everytime, he wouldn’t create support forum. @AdYouWebsFor your main issue I suggest you to remove your domain from control panel then add it again since i assume DNS records for that domain name are corrupted.
You shd always backup before doing anything else, just to be safe.
If your Wordpress was installed using Softaculous, it will be quite easy to create a backup
