Website url is: mrhenrix.ml
And this is the problem im getting
You have a mix of Cloudflare name servers and InfinityFree name servers.
You can’t have both.
It has worked tho but i have to change them back usually just. Currently it has a random SSL certificate i have not even put there.
Yes, the way you have it, sometimes it works, sometimes it doesn’t.
That’s the problem.
Ah. Nevermind i might have a solution thanks for your help anyways
