Whenever I attempt to go to my website (thejatimes.ml) it comes up with an error message that says, “This site can’t be reached: thejatimes.ml’s server ip address could not be found.”, even though I can access my cpanel and the status is active.
HELP!
Thanks in advance,
Blogger Joe
Please try to disable Cloudflare on your domain and see if that brings your website up. Note that disabling Cloudflare changes your DNS records. You don’t need to configure anything else yourself, but it might take up to 48 hours to start working everywhere.
Thanks for your answer.
I disabled cloudflare like you said, but after I did this and visited my website it said: “502 Bad Gateway nginx”. Is this supposed to happen? In 48 hours will it disappear?
Thanks again,
Blogger Joe
@Blogger_Joe said:
Thanks for your answer.I disabled cloudflare like you said, but after I did this and visited my website it said: “502 Bad Gateway nginx”. Is this supposed to happen? In 48 hours will it disappear?
Thanks again,
Blogger Joe
That’s not supposed to happen, but it’s an unrelated issue. Your website is already working again from here.
