My website is not working.
i have install free ssl from cloudflare.
it was working before sometime ago but now it is not working.
cloudflare shows that everything is good at their end and problem is on hosting end so please help me.
I’m sorry to hear that your website is not working. I’m happy to help you, but I do need a bit more information than “website is not working” to do that.
Same is going on for me, please fix it’s urgent
Error 522 to be precise
Please try reading here:
https://support.cloudflare.com/hc/en-us/articles/200171906-Error-522-Connection-timed-out
That doesn’t help, it’s been like this all night. It’s something out my control.
We did not understand anything on that url.
please help us.
Have you change DNS settings ?
@Shivam and @MoonlightCapital
What SSL on Cloudflare are you using currently?
If you might have choose Flexible SSL or Full (Strict) SSL, then this might have cause the error. Please kindly check and if you did set it on Flexible or Full (Strict) then please change it to "Full"
ok i have changed but still it is not working.
Please try clearing your browser cache or data and try again.
i have cleared but still it is not working.
@Shivam said:
you can check my site https://www.citykamarket.com/
Your site doesn’t even load on my end, so IDK what cause this.
Cloudflare might be having trouble connecting through the origin servers (IF servers).
@Shivam said:
@UnknownLolz can you check my cloudflare settings
i will give my account detail.
I would actually okay to do that but I don’t want to know users credentials or anything like that though…
Maybe you can try giving screenshots instead?
