Website not working
Hello sir,
My website admin.taug.in not working.
And I am not able to see error logs etc.
Please tell me why it is not working.
I am Zend framework of PHP.
@someshgaur123 said:
Hello sir,
Your website is showing the error “HTTP Error 500” meaning, your site has a broken code or your php script was too heavy. But I will go to that you have a broken code, please re check your code if you properly code it.
Hello sir,
Hello Sir,
That code is working perfectly fine on local server . But it is not working on your server .
Please check and let me know what is tha error .
Also tell me how can change the virtual host on your server.
Hello sir,
Hello Sir,
First of all what do you mean “my server”, I do not own them. I am no staff or anything.
Your website might have a code that is not supported here on the free hosting servers.
Please give a screenshot on your code.
Please try to enable display_errors in the Alter PHP Config menu or see if the Zend Framework has a debug mode you can use to figure out the error message.
Hello Sir,
Please please help me in just one thing. how can i change the virtual host settings as i have to change the DocumentRoot path and Directory Path. Please help me in this regard. I think after doing this my website will start working
Hello Sir,
In free hosting you don’t have the power to do this operation, considering on buying premium hosting.
