I got up this morning and found my website like this. Screenshot Enclosed
How do you fix this? This happened after I used Cloudflare on the website
Hello there,
Try deactivating some of your plugins one by one to check if one of those plugins you have installed are causing the error.
Also what did you do with your site recently? Did you probably installed some new plugins or something?
It will not let me view my plug-in’s . I just get a White screen of death. I’m at 90% on . If i had to reset my site again my site will be locked for 24hours . As you told me in my last topic
Hi
What happens to you is mixed content
HTTPS works by allowing only content that goes over the HTTPS protocol
while everything on HTTP is ignored by your browser for security
Please try this on Cloudflare
OR
https://support.cloudflare.com/hc/en-us/articles/227227647-How-do-I-use-Automatic-HTTPS-Rewrites-
Please do not use Automatic HTTPS Rewrites. It’s a stupid crutch to hide configuration errors in your website, and it’s an automagic function which tends to cause unexpected errors.
Instead, please follow our official guide on making WordPress work with Cloudflare’s SSL:
