That is correct. You need to install it through FTP.
Yesterday, you reported that plugin installation didn’t work. We provided you a workaround: to install the plugin by hand. And now you’re asking why you need to do that?
You need to do that because the automatic installation doesn’t work. You know that from your own experience.
Yes, because themes and plugins run into the exact same issue with automatic installation. And the manual installation workaround applies to both of them.
So did you try a manual installation of the theme?
