Hi, it has been two times in a row that my website is suspended. Cause is I/O level exceeded. Neither I have cloudflare nor any other caching software. I have 2 plugins and I am in WP 5.4. Please help me. (website classroomomline.epizy.com)
Then try using some caching software !
(you can’t use Cloudflare because you’re on freesubdomain and CF only works if you own a domain)
If it’s consistently being suspended after it got reactivated, then I suggest removing your nameservers and try to detect what’s causing the problem.
how?
Add these to your .htaccess file
#Temporary shut website
Order deny,allow
Deny from all
