I used Mobirise to build my website, and for some reason, the socicons fail to load and the loading arrow continues spinning until I manually stop it. After that, the icons load fine and everything is fine and well.
What is the issue that causes the loading failure and how does manually canceling it, fix it? Also, can I do the canceling automatically, if there is no other way of fixing it?
Maybe you didn’t upload the socicon folder inside of the assets folder correctly, and so you need to do that, and after that remember to clear your cache.
I uploaded the entire assets folder twice manually, and even if there was an issue there, I don’t think the icons would be able to load after manual action. And clearing cache didn’t fix it too.
Mobirise didn’t create that file, and it doesn’t appear on my local filesystem as well. I guess it is unnecassary. Also, the icons load when you first visit the homepage, but the issue I described starts occurring after you visit another page.
