Hello, i was planing to create a forum website the url will be forum.mydomain.com but i have an problem because i can’t find a good forum software(the site will work for only the forum)
Phpbb.
Ah,
Thats a 1969 style,
I recommend Flarum(still in beta, but Good)
why 1969 and not 1970?
Cuz it is 1969 stlye
yea 6969 style
Yeah more like 4200 style
oh yeaaaaaaaaaaaaaaaaaaaa baby!
Yes let’s not go off topic
how will i download it
You have to do it manually bro,
@anon12237952 is greatly experienced in this,(he will come soon to help you)
Hello, I can’t Guarantee It is Fully Functional
So Let me Give you Steps to do it,
Step 1 - Download Xampp
Step 2 - Start the Apache and Mysql
Step 3- Now Navigate to The Xampp htdocs folder
Step 4 - Open shell there and Install Flarum As Per the docs https://docs.flarum.org/install.html
Step 5 - Create a Test Post And Enable or Install plugins Now itself
Step 6- If you see the Language is Weird Make sure you enabled the English Language plugin
Step 7- Now Export the Database and Files
Step 8- Now upload all the files using Ftp
Step 9- Now Import the DB into If
Step 10 - Make sure you update the site name and DB Details in Config files of Flarum
Now you are Ready to Go!
I can’t Guarantee a Perfect Installation Your Installation May Corrupt Because of No InnoDB support in free hosting.
Hope this Helped you!
GO WITH SMF
Or if u want paid version use (Xenforo)
Use flarum.org as suggested by many
OR
If you want paid version, then go with https://invisioncommunity.com/ instead of xenforo or any other.
Thanks
