Just curious about what version of Xera the client area is using. And did the Admin modify the Xera code?
InfinityFree is not using Xera. We are using a closed source, custom implementation that Admin created and maintains all by himself.
Xera uses (I think copied) the frontend, tabler.css.
Also, our client area has existed many more years than Xera.
But it looks so similar, the login is exactly the same
Yes, that’s what I mean by Xera copied our control panel.
It does look similar, as Xera is using the same CSS framework as InfinityFree.
InfinityFree is about 9 years older than Xera, and has many, many more features than Xera.
InfinityFree is not built off of Xera, Xera is a low-functionality client area system modeled after InfinityFree (And it serves as an awesome starting spot for resellers).
where can i download this software
Many Thanks
