When Importing Astra theme, Importing content keeps looping
After I have finished ftp all the plugin of the theme into wp-themes/plugins via backend Wordpress, and then select the theme via front end and start importing. In the middle of importing theme I got the looping which make the importing content keep 0%. May I know how to fix it? Thank you
Maybe the theme is to big, or something is wrong with your WordPress install? Does importing other themes work?
The article @Ergastolator1 shared only explains how to install the theme, not do content imports. It’s likely that the import runs into the same limits as the installation did.
Maybe there is an alternative way to import the content instead? Maybe the provider of the import system has a guide on how to import content manually.
