I included the basic tier bcoz idk which plan you use,anyways the total of the smallest prices go to $400. So my guess is you spend around $800 dollars per year(This is a very very high amount in India).
And most importantly Thanks for giving us the best free hosting service
Iâm in the Netherlands where mean income is a lot higher than in India. But the hosting costs are still big enough that most people wouldnât be able to afford them if they didnât get any revenue from it. Fortunately, thatâs not the case.
And even then the server setup is already quite cost effective. DigitalOcean is already quite a bit cheaper than Google Cloud (which I used before).
In my opinion the hardest part about a nice looking webpage is that you have to make it fit on mobile or at least fit on a different screen resolution. I was using absolute positioning and width and I found out it doesnât look good at all on mobile
