The address sometimes shows ‘suspended-website’ and sometimes the correct website. A friendly contributor pointed out that it might be because the domain refers to two different IP-addresses which results in unpredictable behaviour.
The free hosting cluster is currently being expanded and upgraded but it’s a bumpy ride. Multiple IP addresses in DNS is one of those issues. iFastNet is working hard to get everything set up correctly which includes this issue.
There is no workaround sadly if you’re using a free subdomain.
well… question is still the same though… what would be the workaround with a paid domain instead of a free subdomain? It has been like this for several days now, I don’t know if I want to pay for a service without knowing how much hassle the workaround is going to be.
If you had a custom domain name, you could move it to third party nameservers and only set the right IP address in there.
Another fix that comes to mind is to remove the domain name from your account and then add it again. That should recreate the DNS records and fix your domain that way.
You don’t have to pay to host your website(s) in InfinityFree.
I don’t know what’s happening with the servers. Admin already told you that they are upgrading their infrastructure and these problems are occurring because of that.
Like you read, according to him this problem occurs with free subdomains.
So, while there isn’t a fix, the alternative is to add either a free or a paid domain to your InfinityFree account.
The only free domain provider that i know of is freenom.com .
If you don’t want to spend money on a domain, you can check them out.
UPDATE: I was writing at the same time of admin’s previous post and only saw his after posting. But he had answered you already.
UPDATE 2: Ignore the whole post since I hadn’t noticed that you already had a custom domain.
