My website epiz_25593468 (elherbalista.com) is showing 403 error:
I’m using Dreamweaver, uploading with ftp. The website works perfect on the local server, once is uploaded to the hosting the links point me to the 403 error page.I saw a possible solution about making a new htdocs folder but couldnt make it work please help. The links are fine: I dont know what to do. Please help
Hello there,
Could you check your files permissions?
The permissions might have been set to be private and inaccessible to the public.
Cheers!
But your website works very well for me from Sri Lanka.
That was exactly the problem thanks
I cant fix this problem i fixed the permissions but it didnt fix please tell me how to fix it
please create new topic for your problem.
