https://thriftyblogs.site/ads.txt?i=1
i want to remove this ?i=1 from the url
the hooligan media support said they cant verify ads.txt as that ?i=1 is showing
so how to remove it
KangJL
April 29, 2023, 5:36am
#2
Read this
When you first open your website, you may see the extra characters like ?i=1 at the end of your URL. This article explains more about what causes it, and what you can do about it.
What causes the ?i=1 suffix?
This extra URL parameter is caused by a security system we use to protect your website. This security system ensures that your website can only be accessed through regular web browsers.
What does the ?i=1 suffix do?
The ?i=1 suffix is a counter. When you first load your website, some …
Since you are using a custom domain, perhaps using CloudFlare will help.
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com )
A video tutorial can be found at the end of this guide, should you get stuck.
You must connect your domain to your InfinityFree account first. Read more here .
------- Set-Up Cloudflare -----…
system
Closed
May 6, 2023, 5:36am
#3
