Response Body <html><body><script type="text/javascript" src="/aes.js" ></script><script>function toNumbers(d){var e=[];d.replace(/(..)/g,function(d){e.push(parseInt(d,16))});return e}function toHex(){for(var d=[],d=1==arguments.length&&arguments[0].constructor==Array?arguments[0]:arguments,e="",f=0;f<d.length;f++)e+=(16>d[f]?"0":"")+d[f].toString(16);return e.toLowerCase()}var a=toNumbers("f655ba9d09a112d4968c63579db590b4"),b=toNumbers("98344c2eee86c3994890592585b49f80"),c=toNumbers("96cbe48fc8b3b361712ae81c10337059");document.cookie="__test="+toHex(slowAES.decrypt(c,2,a,b))+"; expires=Thu, 31-Dec-37 23:55:55 GMT; path=/"; location.href="http://restpage.cf/?i=1";</script><noscript>This site requires Javascript to work, please enable Javascript in your browser or use a browser with Javascript support</noscript></body></html>
@puppet said:
no !! … i’m using chrome n javascript is allow … and when i trying using command prompt like curl http://restpage.cf this is the response
C:\curl>curl restpage.cf
403 Forbidden
403 Forbidden
nginx
not only me… i also ask my friend to check it and have same response …
please check it
403 Forbidden
403 Forbidden
nginx
please check it
@Admin said:
You were talking about using cURL, not Google Chrome, right?
Yes, you can access your website with Chrome because it supports Javascript. cURL does not support Javascript so you cannot load your website with it.
what mean of this cURL does not support Javascript so you cannot load your website with it ??
i trying curl via cmd … can you trying command curl to my website and give the result !!
Javascript is a programming language which is executed in a web browser. We have a security system in place which ensures only regular web browsers which can execute Javascript can access your website.
Google Chrome is an example of a web browser which can execute the Javascript programming language, which is why you can open your website with Google Chrome. However, cURL just downloads the page without executing the code on it, which is why you only see the security code, not the actual web page.
TL;DR: cURL doesn’t work. We know it, because it’s how the system was designed to work. You can only host websites here, so you can only open your page with a web browser.
conclution is you blocking access curl request by user ?
for what security reason ??
and short url website not allowed on this service ??
i’m noob here i need more knowledge
Most automated scrapers, spam bots, vulnerability scanners and other tools you don’t want to visit your website are blocked by this.
URL shorteners can be hosted here. However, it’s your responsibility to protect it against spam and to prevent it from linking to stuff which is against our terms. So if your URL shortener starts to redirect to phishing sites, it will be taken down.
However, I don’t understand how these issues are related. Why would blocking cURL mean you can’t host URL shorteners?
Owh, I tought URL Shortening sites is Strictly porhibited…
An update on the TOS about this would be nice
actually i only need access CURL for a confirm adsense on a-ads.com …
without access curl my adsense cannot get confirmation from a-ads.com …
i ask a-ads.com to use another method but … he only have one method using CURL to verified ads on website …
As much as I would like to help you, it’s impossible to disable this security system, even for individual accounts.
also for premium account … ?
Premium hosting does not have this security system.
It depends on the premium hosting you’re choosing.
We recomend you use our sponsor’s premium service.
They’re reasonably priced with a lot more faster speed and SSD storage.
The link will be given by the admin (Because idk his refferal code)
i actually need free hosting include (open curl) before i started upgrating to premium account … why i need to campaign i need to prepare i need to analytic my service i need to tracking … if i got best and best in 3 month i ready to update to real premium hosting … maybe i must move to another free hostinger that give me access CURL ,
I do not recomended hostinger tho, their limit is kinda unclear
I had a premium account there and the support is slow and also you had to use FTP like Filezilla, the online FTP or Browser FTP is only for premium user and above.
