Why my files in HTML format was deleted automatically right after it was uploaded ?
I’ve scan the file and it wasn’t infected with any virus or malware. The file is an index file for sub folder of my website and the size is less than 10mb.
HI
it may be that the names of some functions in JS or somewhere else triggered protection sys.
try to delete some parts of the code of index.html
and upload it until you notice that is auto-deleted by the protection sys.
(so you’ll find out where the problem is)
I’m sorry about that. The article is out of date and needs to be updated. That’s because, since a short while, a new limit has been set of 1 MB for HTML and PHP files, similar to how there is a 10 kB limit on .htaccess files.
I’m not sure exactly why you have a HTML file which is so big, but maybe you can reduce the file size, or split the file up in some way. For example, you could move inline CSS or JS to separate files, or use PHP to process data sets or combine smaller HTML/PHP fragments into a single page.
Well, that’s not an error. That notice is always shown to remind you about MX records. It doesn’t change based on the actual MX records of your domain.
Thanks for the reply,
By the way I can’t login to the webmail.
When i tried to login the roundcube with email address and password, the page just simply refresh.
