<?php
$name = $_POST['name'];
$servername = "SERVER NAME IN ORIGINAL CODE";
$username = "YE, IN ORIGINAL CODE";
$spassword = "IN CODE";
$dbname = "IN CODE";
$conn = new mysqli($servername, $username, $spassword, $dbname);
if ($conn->connect_error) {
die("failed" . $conn->connect_error);
$sql = "SELECT reg FROM accounts WHERE name = '$name'");
die($conn->query($sql));
How it doesn’t work?
the original code doesnt have the )
Yes it does. Look back at the code you pasted when you created the topic, the right parenthesis is visible.
I don’t know what’s happening here…
start by removing the end-parenthesis from the line where you set $sql
and then also remove the extra end-parenthesis from the die()
call below that.
ive removeed the ) now. It still doesnt work.
Can you re-paste the code here? This time, show all the database information except the password.
Thanks!
<?php
$password = $_POST['password'];
$servername = "sql213.epizy.com";
$username = "epiz_32450514";
$spassword = "/**/";
$dbname = "epiz_32450514_accounts";
die("connection failed" . $conn->connect_error);
$sql = "SELECT reg FROM accounts WHERE name = '$name'";
$result = $conn->query($sql);
die($result);
What is the error now? That code is valid… (but it is highly susceptible to SQL injection)
It shows “HTTP ERROR 500”
Can you turn on error messages?
In the control panel, look for PHP Config (Or something similar), select your domain name, and turn on PHP errors.
What error are you getting?
Fatal error : Uncaught Error: Object of class mysqli_result could not be converted to string in /home/vol2_5/epizy.com/epiz_32450514/htdocs/register/submit.php:15 Stack trace: #0 {main} thrown in /home/vol2_5/epizy.com/epiz_32450514/htdocs/register/submit.php on line 15
Maybe this will be useful to you
