Woocommerce importer error
Website URL
https://thealidev.epizy.com/
Woocommerce importer got stuck on imported products screen
And it says “adding new attribute failed.”
Idk what is problem
Can you tell me a solution
I also tried splitting csv
Specified in error msg
Hi and welcome to the forum
What is your version of woo ?
I see you are not the only one with this problem
In short, some solved it by updating to the latest version
or rollback to version 7.7.2
Ok
I try and tell you
I still struck on import screen
But the error you mentioned got solved
But why am i struck
Why is importer struck on infinity free @Oxy
There may be:
  • insufficient memory for WP and Woo (the hosting limit is 128MB)
  • as well as the limit on the maximum execution time for PHP (60sec)
  • conflict with some plugins (try disabling all plugins)
Try enabling debugging and see what you get
[09-Jul-2023 16:46:56 UTC] PHP Warning: mysqli_real_connect(): (HY000/1203): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2019
[09-Jul-2023 16:46:56 UTC] PHP Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:46:56 UTC] PHP Warning: mysql_connect(): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:46:58 UTC] PHP Warning: mysqli_real_connect(): (HY000/1203): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2019
[09-Jul-2023 16:46:58 UTC] PHP Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:46:58 UTC] PHP Warning: mysql_connect(): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:47:03 UTC] PHP Warning: mysqli_real_connect(): (HY000/1203): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2019
[09-Jul-2023 16:47:03 UTC] PHP Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:47:03 UTC] PHP Warning: mysql_connect(): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:47:04 UTC] PHP Warning: mysqli_real_connect(): (HY000/1203): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2019
[09-Jul-2023 16:47:04 UTC] PHP Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:47:04 UTC] PHP Warning: mysql_connect(): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:48:47 UTC] PHP Warning: mysqli_real_connect(): (HY000/1203): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2019
[09-Jul-2023 16:48:47 UTC] PHP Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:48:47 UTC] PHP Warning: mysql_connect(): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:48:48 UTC] PHP Warning: mysqli_real_connect(): (HY000/1203): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2019
[09-Jul-2023 16:48:48 UTC] PHP Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:48:48 UTC] PHP Warning: mysql_connect(): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:49:23 UTC] PHP Warning: mysqli_real_connect(): (HY000/1203): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2019
[09-Jul-2023 16:49:23 UTC] PHP Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
[09-Jul-2023 16:49:23 UTC] PHP Warning: mysql_connect(): User 32717021_a already has more than ‘max_user_connections’ active connections in /home/vol5_3/epizy.com/epiz_32717021/htdocs/wp-includes/class-wpdb.php on line 2051
How to export whole mysql and import to new one
I will host and set it myself
And also tell me solution of problem after new db @Oxy
Go in to phpMyAdmin, select your db, click export.
it will give you a .sql file
