woocommerce installation 3.8.0 failed
What can i do.?
What is the error that shows you while trying to install WooCommerce?
Its showing
Installation failed: There has been a critical error on your website. Please check your site admin email inbox for instructions.Learn more about debugging in WordPress.
Please help me
Did you check your admin email inbox and learn more about debugging? If not, that would be a good place to start.
After all, a good error message helps you to solve it’s cause.
They not sending mail…what can i do…but 10 or 15 days ago woocommerce installing perfectly…
Try to download the fresh zip file from here, extract it on your computer, then upload the extracted folder to htdocs/wp-content/plugins
or yourdomain/htdocs/wp-content/plugins
folder, replacing yourdomain
with your domain, with a FTP client, overwriting all the existing files if needed.
