Woocommerce Plugin incomplete
Hi,
I just started my own WordPress site and I tried to install WooCommerce via the “Add plugin” tab inside WordPress. However, it reported “Update Error!” the first time I installed it. Then when I checked “Installed Plugin”, WooCommerce appeared there; so I activate it, but it says “Your installation of WooCommerce is incomplete. If you installed WooCommerce from GitHub, please refer to this document to set up your development environment.” And WooCommerce Wizard didn’t pop up either.
I tried to deactivate it and delete it, then installed it several times, but the above error message still appears. Please help.
Thanks a billion!
Maybe try to deactivate and delete it and this time install it via FTP with the following instructions:
https://wordpress.org/support/article/managing-plugins/#manual-plugin-installation
Hi,
first go to the panel
FILE MANAGER and you sears file “htdocs” and open “wp-config.php” edit and paste this:
define( ‘WP_MEMORY_LIMIT’, ‘128M’ );
for example:
<?php define( 'WP_MEMORY_LIMIT', '128M' );
