Hi, I have uploaded wordpress to my addon domain tubesocks.ml but im having problems connection to the mysql database so cannot continue with the installation
I have also tried entering the details manually into wp-config.php but get an error message “Error establishing a database connection”
Any ideas ?
Thanks
Maybe there is a problem with Database Connection, try again and tell me what it shows.
@Galaxip said:
yeah its working fine now with the same settings
Ok glad it works.
I had the same issue, but it was only a temporary problem from SQL Server.
If you have any other problem, don’t hesitate to ask the community here
There was a problem with Byet/iFastnet SQL servers that they provide to InfinityFree.
It only happened in the early and middle hours of the day, and now it is solved.
