Hello,
I am trying to install but it will not allow me.
See screenshot. Please suggest solution.
Thanks
Hello,
Thanks
Can’t upload screenshots.
Basically I click on the Install Now button and I can see javascrtip.tabs.tab(install) in the status bar, but it does not go any further.
@ananda said:
Can’t upload screenshots.Basically I click on the Install Now button and I can see javascrtip.tabs.tab(install) in the status bar, but it does not go any further.
Are you installing through Softaculous?
Anyway, have you tried clearing your browser’s cache and then trying again?
Yes I am trying through Softaculous. Will just try to clear all cache and see if that works
So I cleared the cache and I am trying the installation again. Now it asks me configuration details for WP. Does that mean, it has already been installed?
But before that I have another issue. I read that the Free Hosting comes with a Free SSL. I want to configure my WP installation with the https. So how do I configure the free SSL to my account?
Thanks
I came across this post -https://forum.infinityfree.net/discussion/2149/free-ssl-certificate-providers-that-can-be-used-with-infinityfree
Does that mean Free SSL doesn’t work anymore with Free Hosting package.
@ananda said:
I came across this post -https://forum.infinityfree.net/discussion/2149/free-ssl-certificate-providers-that-can-be-used-with-infinityfreeDoes that mean Free SSL doesn’t work anymore with Free Hosting package.
Kindly prefer to this discussion which provide the latest way of SSL. https://forum.infinityfree.net/discussion/2951/how-to-get-ssl-even-on-subdomains#latest
I decided to write an article on forums so just follow my steps.
Let’s Enrypt
Sign Up for Infinityfree
Transfer your domain to Infinityfree by changing nameservers
Sign Up for Cloudflare
Transfer your domain to Cloudflare by changing nameservers
Wait it is the same steps chill bro wait for next steps
Goto www.sslforfree.com
a) Enter your domain
b) Select Manually Verify Domain (DNS)
c) It will give you some TXT records to
d) Copy Them
Goto Cloudflare and select DNS mangement
Paste the Records(TXT) that you copy
It will give you private key and certificate
Open cPanel select SSL/TLS
Select your domain
Upload Key First
Upload Certificate
Congrats you installed the certificate
the above mentioned are the only ways of getting SSL/TLS for free on free hosting using Infinityfree.
Note: By the use of second step repeat the same steps for subdomains as for main domain
Note2: By using Cloudflare add A record of subdomains pointing towards your IP and enable traffic through CloudFlare
Congrats it’s enable! Hope you enjoy!
I followed your instructions till - Cloudfare Signup.
ok found them in help
guss.ns.cloudflare.com
pola.ns.cloudflare.com
Will just update and check back.
The nameservers have been configured. But now I get an error
An MX record was not found for your root domain. An MX record is required for mail to reach @interactivegdpr.online addresses.
I checked my domain server DNS area. There are no MX records as of yet. And I have not configure any email for my domain yet. So do I need to do that first?
@ananda said:
The nameservers have been configured. But now I get an errorAn MX record was not found for your root domain. An MX record is required for mail to reach @interactivegdpr.online addresses.
Setup MX record mx.epizy.com pri. to 10
- Cloudflare
- Sign Up for Infinityfree
- Transfer your domain to Infinityfree by changing nameservers
- Sign Up for Cloudflare
- Transfer your domain to Cloudflare by changing nameservers
- Your Site will not affected by changing nameservers
- Goto Crypto and SSL security and select Flexiable
- Congrats you have install SSL
But Cloudflare SSL are not for your domain it is common name issued to sets of domains and are specified to some browsers but it is easy.Let’s Enrypt
d) Copy Them
Select your domain
Upload Key First
Upload Certificate
@ananda
Do not select Flexible as @Ranakhas said, it breaks WordPress.
Select the full option instead, and also instead of this whole proccess you could have used the 1-Click CloudFlare enabled in cpanel, it is not your fault as you didn’t know but I am just telling you for the future.
Good Luck!
Selected the Full option, basically it was the default.
Also got the detail to add the MX record in CloudFlare - https://support.cloudflare.com/hc/en-us/articles/218069617-How-do-I-add-or-edit-mail-or-MX-records-
Also came across the Cloud Flare option in cPanel under software.
It seems like I have configured the SSL? How do I temp check the site url with https?
Ok so I have configured the SSL, it seems, atleast at the CloudFlare end. When I go to the WP setting and choose Protocol as - https://. I get the following error -
A trusted SSL Certificate was not found
So how do I check the SSL installation?
@ananda said:
Ok so I have configured the SSL, it seems, atleast at the CloudFlare end. When I go to the WP setting and choose Protocol as - https://. I get the following error -A trusted SSL Certificate was not found
Note that Cloudflare takes up to 24 hours to set up the certificate for a domain.
@ Admin
Got that. Let me check back in 24 hrs.
Thanks
@Admin
So I checked my sites and it gives me a GreenLock Secure sign. But when I go to install WordPress it gives me the same error i.e
Further suggestions?
@ananda said:
@Admin
Ignore this message and proceed, I had it also and nothing happened.
It is caused becuase you have no SSL installed directly at your origin server, CloudFlare ones are served thorugh CloudFlare and are not installed in the origins server (InfinityFree).
So finally after the SSL and Login Error issues resolved - WP has been installed.
Thanks everyone for all the help.
@ananda said:
So finally after the SSL and Login Error issues resolved - WP has been installed.Thanks everyone for all the help.
You are welcome, happy WordPressing!
