I am trying to login wp-admin i just created and its not going through.
Hello there,
Do you have an SSL certificate installed on your site? If not then that’s probably why you are experiencing the issue.
To get a free SSL certificate you can go to the client area and on the menu you should see a “SSL Certificate” tab. Follow the instructions it will give you.
Let me try it. thanks
@unkownlolz, i have added the ssl certificate and its still showing the same thing
You also need to install it on your hosting account, then wait a while until the SSL certificate changes have propagated and visit your website again.
Hello there,
Try inserting this code into your .htaccess file:
RewriteEngine On
RewriteCond %{HTTPS} off
It worked… i gave it a little time and reload. Thank you all for the info
