I have problems with the default themes in wordpress, also installed the astra and generatepress templates and they gave me the same error. Blank to customize the template.
This error’s major source is outdated wordpress. See if you have the latest version of wordpress which is 5.4.1. If it is an older version, update now! If it does not fix the issue, deactivate all of your plugins, and see if it is solved. Now, reactivate the plugins one by one while checking if the customizer is working. After you have found the culprit, post it here so others will know about the conflict and I can suggest some alternatives for that plugin!
Hello. I think the it has todo with PHP FILE UPLOAD LIMIT. The is corrupted after the uploading process. I also have that problem before but I resolved it by:
1. Manual Installation of Wordpress Themes
Steps:
Open the File Manager and navigate to:
/wp-content/themes
Then, upload and extract the Astra zip file in that directory. Wait until the extraction process done.
How about @JavesPotato I did the steps you wrote, it worked for a while but I think that when installing a plugin start templates I think it gives me an error. I’m not sure, but he did the first if it came out. They will have some conflict with wordpress because no template comes out empty in the customize view.
