Wordpress problem, fatal error
My website URL is:
https://www.tenkango.xyz/
What I’m seeing is:
Fatal error
Warning : require_once(/home/vol15_7/epizy.com/epiz_23885154/tenkango.xyz/htdocs/wp-content/plugins/jetpack/load-jetpack.php): failed to open stream: No such file or directory in /home/vol15_7/epizy.com/epiz_23885154/tenkango.xyz/htdocs/wp-content/plugins/jetpack/jetpack.php on line 146
Fatal error : require_once(): Failed opening required ‘/home/vol15_7/epizy.com/epiz_23885154/tenkango.xyz/htdocs/wp-content/plugins/jetpack/load-jetpack.php’ (include_path=‘.:/usr/share/pear/’) in /home/vol15_7/epizy.com/epiz_23885154/tenkango.xyz/htdocs/wp-content/plugins/jetpack/jetpack.php on line 146
I’m using this software:
Wordpress
Additional information:
I can’t download any Plugin, etc. My wordpress are just weird. I’ve reinstalled it and still has the problem.
This error am I seeing 24/7 when I try to download something…
The error message looks quite obvious to me: it says there should be a file in the jetpack plugin, which doesn’t actually exist.
The solution is to remove the broken plugin and install it manually. This process is described in this article:
