I accidentally changed my wp-admin url from mysite/wp-admin settings, so now is there any way to change it manually as I am not able to access my website’s admin pannel dashboard.
To regain access to your WordPress admin area, you can do the following:
- Login to your client area, find your hosting account, click Manage and then go click Control Panel.
- Go to phpMyAdmin, find your WordPress database and click Connect Now.
- Find the table with the name ending with
_options
and click on the name. - Find the rows with the column
option_name
matchingsiteurl
andhome
. These should be the first two in the list, but you can use the Search function if you can’t find them. - Double click the value in the
option_value
column, and change the URL
