website: mytestblog.gq
The error i get is;
See this site for more: How to Fix Error Too Many Redirects Issue in WordPress
This is usually due to an SSL/redirection issue, the article above should be some help
DO NOT USE FULL MODE WHEN USING HTTPS CLOUDFLARE ON YOUR SITE INSTEAD JUST USE FLEXIBLE MODE
This is due to mixed content. If you open up the console, you will see many mixed content errors. There are many ways to fix this, but this is the way I use:
Go to wp-config and then insert this code :$_SERVER['HTTPS'] = 'on';
right after <?php
It should look like this:
This way, you can use your wp-admin.
