http://themessageforhumanity.org/contact-us
The emails are not being sent when a form is submitted, works fine on other hosting, just infinityfreee not working
It is because one thing. InfinityFree doesn’t allow pop email in free hosting, but there is an easy solution.
Just go to the Vista panel, and go to “account upgrade”, select which plan do you want, and order ifastnet.com to migrate everything.
I hope I helped you!
The php emails are heavily checked and blocked for a workoaround Is it possible to remove advertisements (which seem to come from ifastnet) when sending registered email with WordPress? - #2 by Admin
Why upgrade to premium when there’re free alternatives, I suggest you to use wordpress plugins for Gmail SMTP.
