www.wallcart.in took too long to respond.
what is this problem i cant understand my word presspanel is not opening.
and tell me in a free hosting how much trafic can i get in a month.
The domain wallcart.in doesn’t work because it doesn’t have the correct DNS records. You can try to correct these DNS records yourself through Cloudflare’s panel or you can change your domain’s nameservers back to our nameservers.
As for the limits, you can find the statistics in the control panel of the hosting account.
now my wordpress admin panel showing white screen when i am going for login
whether your site is infected or has some issues
there are some strange redirects
Request 1: https://wallcart.in/wp-admin/
URL: https://wallcart.in/wp-admin/
Host: wallcart.in
IP: 104.18.45.170
Error / Status Code: 302
Response Headers: RANDOM
status: 302
after that
URL: http://mcc.godaddy.com/park/nz55rKOhMJphqzR=
Host: mcc.godaddy.com
IP: 184.168.131.213
Error / Status Code: 200
Priority: HIGHEST
Protocol: http / 1.1
Initiated By: https://wallcart.in/wp-admin/ line 0
it’s possible that you have a problematic plugin and for that reason you can not access
to admin login page
TURN ON DEVELOP. MODE IN CLOUDFLARE
https://support.cloudflare.com/hc/en-us/articles/200168246-What-does-Cloudflare-Development-mode-mean-
come over FTP in the wp-content/plugins/
rename that folder to pluginsXXX
and then try login at admin page
if you can login after that
then return the original folder name
and remove the plugins through dashboard
the same procedure is for a problematic theme
just rename folder themes
these redirects look like this
Status: Resolving address of wallcart.in
Status: Connecting to [2400:cb00:2048:1::6812:2caa]:21…
Status: Waiting to retry…
Status: Disconnected from server
website is not connecting with file zilla now how can i do it
showing these errors
your host is wrong- is not your domain
go to the client area> manage
and scroll there to FTP data section
you also have a button to show pass --click it
or use monstaFTP from client area
i cant under stand wht you want tell i have not geting ftp data section
please explain it step by step
are you infinityfree user or not?
yes i am using free plan
ok go to client area Login to your account - InfinityFree
manage account (green button)
scroll down to FTP Details section
use that data for config. filezilla client
or use monstaftp from client area (go to file manager button)
all details i have been enterd in filezilla now showing that
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 662 of 2900 allowed.
Response: 220-Local time is now 13:46. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220 You will be disconnected after 60 seconds of inactivity.
Command: AUTH TLS
Response: 502 AUTH TLS OK.
Command: AUTH SSL
please try this
edit your “site” settings > encryption >use plain ftp (number 9. image)
https://help.crucial.com.au/hc/en-gb/articles/202706650-How-do-I-setup-FTP-in-Filezilla-
The domain doesn’t seem to be hosted by us, I see some unusual data in the response which isn’t normally sent by our systems or by WordPress. Can you please check your DNS settings in Cloudflare and verify the IP address configured for your domain matches what you find following this guide?
i am using cloudflare in betwen hosting and domain not from infinity panel direct from cloudflair. com so may be it is a problem
and i have added cloud flare name servers in my domain name not for infinityfree
OMG :smiley:
Within 10 hours I have seen more than 5 versions of the problem
from CF ray with DNS errors and some 5xx
to a white page that actually does this if you click ctrl + F5
i am reseting every thing i will try from different account
