www.wallcart.in took too long to respond.
or tell me any suggestion to solve this error
Start by disabling Cloudflare. Cloudflare can be useful if everything is working well, but is another moving part which can cause trouble if there is a configuration issue. Disabling it rules out a number of possibilities for issues.
word press panel showing website coming soon means?
a word press ssl plugins are secure can i use ssl plugins for https connection?
I see you returned DNS from CF to IF
wordpress seems OK as well as the admin login section
of course only via http !
http://wallcart.in/wp-admin/
http://wallcart.in/
for https (free cert from CF) wait for the green light from admin
as well as the DNS propagated completely
Your account is suspended this could be due to reaching limits of your hosting plan or for abuse.
now what is this i want to cry right now i am irritate from these things pleas solve my problem
when i go for generate csr for ssl certificate then its showing i have read knowledge base article related to this for creating a review ticket but there is not showing option for it
when i submit my csr then not giving new csr private key etc
Domain “wallcart.in” challenge3 failed. Response from “https://acme-v02.api.letsencrypt.org/acme/challenge/7iWsB_Waa3P9OPRzWHvhOBI8SeV9riLVGGJf_Oa6FZE/7377940828” was:
Warning: Your verification URL is not returning the correct contents to our verification servers. The URL looks like it is blocking bots and which inadvertently blocks our servers from receiving the correct content. Contact your host, a professional developer or admin for further help with fixing it.
Error: Invalid response from http://wallcart.in/.well-known/acme-challenge/xytHzu7xr0VQn8gDJg2TCaCkq2Gisoy4-VAzvL7Ta2w: “function toNumbers(d){var e=[];d.replace(/(…)/g,func”
Full Error: { “type”: “http-01”, “status”: “invalid”, “error”: { “type”: “urn:ietf:params:acme:error:unauthorized”, “detail”: “Invalid response from http://wallcart.in/.well-known/acme-challenge/xytHzu7xr0VQn8gDJg2TCaCkq2Gisoy4-VAzvL7Ta2w: "\u003chtml\u003e\u003cbody\u003e\u003cscript type="text/javascript" src="/aes.js" \u003e\u003c/script\u003e\u003cscript\u003efunction toNumbers(d){var e=[];d.replace(/(…)/g,func"”, “status”: 403 }, “url”: “https://acme-v02.api.letsencrypt.org/acme/challenge/7iWsB_Waa3P9OPRzWHvhOBI8SeV9riLVGGJf_Oa6FZE/7377940828”, “token”: “xytHzu7xr0VQn8gDJg2TCaCkq2Gisoy4-VAzvL7Ta2w”, “validationRecord”: [ { “url”: “http://wallcart.in/.well-known/acme-challenge/xytHzu7xr0VQn8gDJg2TCaCkq2Gisoy4-VAzvL7Ta2w”, “hostname”: “wallcart.in”, “port”: “80”, “addressesResolved”: [ “185.27.134.148” ], “addressUsed”: “185.27.134.148” } ] }
Hi,
This is due to the security system.
i want to know only one thing how can i get free ssl certificate for my website which website you allow which not and tell me the step by step procedure please.
  1. Find an SSL vendor you like.
  2. Follow their instructions.
i have tried sslforfree.com but they give me the option to make folders .well-known and acme-challenge but in my file mennager have no public html so i make in htdocs and i upload the files the 2 files in acme-challenge folder then check the link but the link is opening my website means not working so tell me these correct step to do.
Hi,
Didn’t I already provided an answer to you above?
You can’t get free ssl from Let’s Encrypt here since its blocked by the security system, you can use Cloudflare to get free ssl instead.
so tell me the the cloud flare procedure
Sign Up for Cloudflare
Transfer your domain to Cloudflare by changing nameservers (Your Site will not affected)
OR:
You can use the CloudFlare integration on cPanel
GENERAL STEPS:
  1. Go to the Crypto Section of your Dashboard then go to SSL
  2. Select Flexible SSL if your hosting provider does not have an SSL already installed or Full if your provider has a certificate installed. For InfinityFree select Full SSL.
  3. Congratulations! You now have installed free SSL! Keep in Mind that it might take a few hours for the certificate to install.
Source from Techub
https://techub.pw/blog/get-free-ssl-with-free-hosting/
Or, for even better, checkout this video:
Powered by TechHUB, a video by @ChrisPAR
i have completed all steps from this video but now also not opening my wp control panel
https://www.wallcart.in/wp-admin/ whai showing you check manually
ok its working no problem thanks for your big support
TELL ME ONE LAST THING SHOULD I USE WORD PRESS SSL PLUGIN?
No, a properly configured WordPress installation doesn’t need any third party plugins to use HTTPS URLs.
