Xenforo error
Website URL
kingtanks.rf.gd/forum
The following warnings were detected when verifying that your server can run XenForo:
  • Your server has disabled a core PHP function exec via the disable_functions directive in php.ini. This may cause unexpected problems in XenForo.
  • Your server has disabled a core PHP function escapeshellarg via the disable_functions directive in php.ini. This may cause unexpected problems in XenForo.
  • Your server has disabled a core PHP function proc_open via the disable_functions directive in php.ini. This may cause unexpected problems in XenForo.
  • Your server has disabled a core PHP function popen via the disable_functions directive in php.ini. This may cause unexpected problems in XenForo.
  • Your server has disabled a core PHP function set_time_limit via the disable_functions directive in php.ini. This may cause unexpected problems in XenForo.
These will not prevent you from using XenForo, but they should be resolved if possible to ensure optimal functioning. However, you may still continue with the installation.
Is there a way i can enable those ? because if i will press continue my whole xenforo board will just mess up and will not work, please help me
No.
XenForo aren’t meant to be run on free hosting. I believe that for someone that had paid $100+ for a XenForo license, premium hosting should be a no-brainer.
And to add to what @Frank419 stated, if you download XenForo and didn’t have to pay a dime for it then it is certainly pirated. Pirating software is illegal, and we don’t permit pirated software on our hosting, so if you did that knowingly and willingly, expect your account to be suspended permanently; if you didn’t know, then remove the installation and find another software, such as Vanilla.
