Yoast Seo Plugin - Infinityfree
Hello Infinity World,
I have a Wordpress website (installed by the Softaculous-Apps-installer application) on infinityfree.
And I want to install the Yoast Seo Plugin, however, every time I have to install by wordpress within the infinityfree the plugin does not install and it say that is like “failure”, I have also tried to manually download by zip and uploading … and it gave the same failure. has anyone had this same problem and knows how to help me? thanks in advance.
Can you please try an actual manual manual installation, like we’ve described in the KB article about this error?
Thank you :heart: , I will check and reply later.
Thank you @Admin, the link you sent me helped a lot, it’s perfect! thanks again.
