0x748c
#1
File Install.php
Please enable zipLibrary,
Or if its disabled forever, please answer why.
Thanks,
748
Refer to this topic please:
0x748c
#4
So if i install it now without extension, and then problem will be solved, it will be working as intended or i will need to reinstall it?
you can change your php version and try
0x748c
#7
Then full script not works because it requires php 7.x
system
Closed
#8
