How to do logging in Logflare
You just add your domain in InfinityFree and configure Cloudflare, it’s awesome. But seeing just a few charts on the CF dashboard may confuse you. This guide explains how to configure Logflare, get to know where your visitors are from, and what browser they’re using.
Sign up for Logflare in here > Logflare | Cloudflare, Vercel & Elixir Logging
You can use Google SSO, GitHub SSO, or traditional email and password creds
Once you’re in the Logflare dashboard, click
New source
, and name itYourDesiredName.all
Your log source is created, and the
Send logs to this source
popup will show up. Scroll down until you’re on theCustom Cloudflare Worker
section. Copy the worker code for later.
Open the Cloudflare dashboard and head to
Workers and Pages
In case you don’t have existing workers, click
Create worker
You may change the worker name first, and click
Deploy
Once your worker is created, click
Edit code
Remove the existing code for
Hello world
, paste the worker code you get earlier from Logflare, and clickSave and deploy
Go back to your worker’s Overview, and click
Settings
Click
Triggers
and scroll to theRoutes
section.
Click
Add route
, enter*.yourdomain.com/*
on theRoute
field, select your CF zone that corresponds to your domain, and clickAdd route
Happy logging!
