I have a final now, wish me luck!
Best of luck to you!
I had some time on my hands (Actually Iâm procrastinating, can someone yell at me?) so I decided to try to find an answer (I was interested as well).
After finding a bunch of files that were unrelated to discourse (We all love google), I was unable to find anything that suggested that flags âexpireâ. I did find a reference about them not though. Hence my conclusion that the only way for you to get Level 3 status is for:
(A): For an Admin or Moderator to dismiss the flags you currently have
(B): For an Admin or Moderator to override the system and grant you level 3 status.
-If (B) is used, you would be stuck at Level 2 until an Admin or Mod granted you Level 3 should you happen to dip below a different requirement (I think, this is the only one I am unsure of).
Hope the clears up any confusion on the topic.
What, there was a power outage in your area over there
Huh, what? I canât remember the last time I had a power outage! But sadly for the unfortunate folks in Kentucky and Tennessee this isnât true . Letâs all pray they get better!
I donât think I did well (I got an A last big test. This one is probably closer to a B or a C)
Also my Chromebookâs touchpad is messed up
I had one of those only a few blocks from my house once, the path it took is still without trees, and looks miss-placed from everything around it (It feels too open).
Hopefully everyone is able to rebuild, and havenât lost too many of their possessions.
Lets hope for the A! I have a quiz in chemistry tomorrow, as well as a Math final. And a chemistry final on Wednesday, and another math final on Thursday, and another chemistry final on Friday, and about three othersâŚ
IT?
Wait, u have finals in high school? HuhâŚ
I donât want to ruin the progress I have on my chromebook right now (things that usually donât transfer to another chromebook). After my PSEO class, I will likely ask for a new one (or get it fixed. I think it is a system issue and not the touchpad itself, as it works fine sometimes and at other times it doesnât).
You dontât? (Markdown cannot allow me to create the large emphasis I want on that word)
No. We have MCAs and quizzes on subjects.
Well, itâs nice (to be honest with you, I donât study for quizzes and tests. My high school allows open note quizzes, but for my PSEO doesnât, and even then the most studying I do is reviewing what I know and what I forget in my head and then re-learning what I forgot) to not have them
Can we switch schools?
Trust me, itâs too easy. Much too easy.
I almost asked for the name of your school and gave you the name of mine XD
Finally someone likes the pictured cat
False, our values being the most important!
100 days !
like everything else in that section and is related to the date of creation of the post that is flagged
because of that
I often choose âignoreâ if a user flags his post so that it will not affect TL3 in the future
Unless, of course, that flag is serious?
for serious flags
staff gives silence
, suspend
or permanently terminates
acc
