When I searched it nothing came up, they must have already been deleted.
I’ll try that, thanks!
you may have exceeded your log size limit though I doubt it, because that would mean you were under DDoS
You have a calendar there so you choose the last three days or yesterday
if it throws out an error then you select the hours below
and manually click on the charts below that appear after search
or you search with some term etc.
I know it’s not easy but I’m sure the logs stay there for three days
CF is in the middle here
visitor - CF - hosting server
and then whoever visits your site
server sees it as CF IP
because CF actually talks to the server and everything goes through it
(there is no direct visitor<->hosting connection)
so you need to use some of the ways for CF to pass the real IP from the user to the server
There are several ways but this is the free one I gave you above (code - and then you just call “$ipoxy” wherever you want it to print/echo/save IP from the visitor)
the easiest way is to write 404
in search and press enter
and it will list all 404 returned by the server
and that’s what you’re interested in
because someone did a vuln.test and looked for directories that don’t exist with you
and you find it so easy
as you see three days back
That’s basically what I do, and nothing is returned if it happened more than 24 hours ago. If I go into settings, it tells me that logs are only stored for 24 hours.
what do you see here when you go to EDIT and then all the way to the bottom?
if it says 1
try putting it on 3 and see if it throws out an error
my maximum is 3
then the limit was lowered for newer users
try 2
then I’m sorry
when I was doing the configuration it was more than enough 3 days
ok then it’s better to find another service or just redirect (sink) the logflare to some free log server and store all the logs there
that I am in your place - I would contact them
and asked them what this number 3 (days) means
here (project tab) Logflare | Cloudflare, Vercel & Elixir Logging
and then further asked why you are not able to put 3 but only 1 is allowed.
or that page is out of date
or something is wrong with the settings
It would be best to be homogenous with the errors, so not just returning 403 if it exists and they don’t have access.
That way, they can’t use logic to determine what your website uses. Otherwise, it is like giving a hint without revealing the secret, a very, very helpful hint!
Ah, this is … awesome.
A group domain name that I am looking into purchasing just had one of them bought, and it has very questionable content on it. And now I either buy the rest and risk people spelling things wrong and landing there, or I can redo a bunch of other stuff, and brainstorm a new name. sigh
Part of WHOIS:
Registrar URL: http://dnsgulf.com
Updated Date: 2022-03-18T18:40:05Z
Creation Date: 2022-03-18T18:40:05Z
Registry Expiry Date: 2023-03-18T18:40:05Z
Registrar: Hongkong Domain Name Information Management Co., Limited
Who likes my Windows 11 taskbar?
RetroBar is my secret.
Who likes my Windows 11 start menu?
Open-Shell is my secret
I must be quiet now that I have revealed all of my secrets!
I am way too young for windows 7
Heh! I grew up using Windows XP (the taskbar above) and then I used 7 until I felt comfortable with 10 in 2016.
What is odd is that I have found myself coming back to 7 again and agian now more than ever, because other thingies just won’t cut it .
Also, i had a revelation today: i was like, “why dont i just use linux (ubuntu)? all of my software would work… and theres nothing that i need windws for, let alone windos 11.” so i see some dual-booting in my future
Welcome to the realm of dual-booting
Anyone from India here ?
UI of linuxfx is similar to windows as well
Yeah, why?
Just asking !
I never had a computer until a few months before windows 11 was out (last september)
But yeah, my grandpa’s computer had a windows 7-looking bar (not as retro as yours), but my dad must have fiddled with that. I don’t know if he used retro bar, I’ll have to ask him. Might even be a mode on windows 10 or something (doubt it, I rip through the settings of pretty much any electronics I get that get them and I haven’t found it yet)!
Well, the IT department here now blocked replit (I kind of know why…)
I think they are proving themselves to be more paranoid by the every step they take.
Time to bring out the jokes!
What is the difference between China and my IT department?
Unlike my IT department, China actually supports public education
