Where?
Client area.
I thought client area had 960 px to * px bannersâŚ
My baby was suffering yesterday.
My game performance was so bad, so I looked⌠and THE GPU TEMP WAS 88C!!!
Yeah, apparently the fan speed is based off of the fan temperature sensor, which only read 2C (although that was wrong, because the GPU temp sensor was reading the correct temp).
Also, my performance mode macro wasnât working (although the mode could be switched on from the control panel). I ended up having to keep the fan speeds at max for the entire game instead of running them as needed.
And my dad says that computers shouldnât allow users to adjust the fan speedsâŚ
Yeah, the throttling saved my GPUâs life, but if it has to throttle to the point where the clock speed is only around 300 MHZ, then thatâs bad.
Itâs up and working today, IG shutting it down instead of restarting fixed the problem.
Gotta like this post in a Heartbeat
Failure to like this post will result in an Incoming event so grisly that it will blow your mind (Make sure you listen for the Emergency Broadcast)
@Oxy if you donât like this post within 3 seconds of seeing it, I will have no choice but to send Gammer to your door to perform a full-blown concert for you >:)
I wonât tell you the Nitti Gritti details, but Gammer is an Underdog and will stop at nothing to do it!
Although some of you argue that it may bring you Joy
But letâs not Digress about how Melancholy he can be sometimes.
Because when Brostep strikes back, The Drop is so bad that you will want to Get Crunk. So letâs CRANK UP THE DANK!!!
When will this stop? This is almost Superhuman, but you gotta admit that this makes you want to Stay Tonight and binge-listen to him.
Ok, now there is a Beam of Light, as the last few songs rise to you and the end is nigh. Maybe the Party Donât Stop, but if it does then Donât You Say You Love Me. You needed me and I Needed U to hear my awesome playlist. This might be Over the Edge, but trust me when I say I love to Feel Like This.
Well, Iâm done now!
This feels like the grand finale of fireworks, because man⌠compared to my usual posting this is EPIC. Donât think itâs done, however.
Iâll be back, just you wait
First person to listen to them all gets a cake! Yum!!!
good morning.
same here. Which timezone do you live in?
GMT+7, evening now
No - itâs a robot like a Roomba vacuum cleaner
designed to clean around inside server rooms
which we allowed to share advice and impersonate
for the simple reason that robot is not bored while wandering the floor alone surrounded by servers
and because it is a more advanced version than the regular one.
My banger song too!
Yes , he is.
Glad you know Niviro
His âVoices in my headâ is an even bigger banger IMO.
I messed up so badly in Math class (Algebra 2.1 - we split algebra 2 into 2 parts), that I actually asked âwhatâs 2x + 3xâ!!!
Yeah, I was that confused to the point where I started questioning basic things.
How is that a bad thing? Itâs actually a very hard problem. After consulting my calculator, I can confirm that not enough information exists to get an accurate anwser. The table below may be of some use.
If X is⌠| Anwser |
0 | 0 |
1 | 5 |
2 | 10 |
3 | 15 |
5 | 25 |
10 | 50 |
Combining the equation, I mean.
Itâs 5x, but I was in such a clouded mind that I didnât trust myself.
I know
Can you solveâŚ
` = 5 " = 6 \ = 7 ) = 8 - = 2 ^ = 6.5 * = 9.8 ; = 3.4 )`"`\ = ???
