Same, i hate its suggested words.
YES. You and your phone keyboard is nsfw.
One form of intelligence is bypassing the problem
so there is nothing wrong with cheating
how to solve a problem with as little effort as possible…
Whats your opinion on this statement :
Notepad is the best HTML editor.
no, that is visual studio codes
Noooooo, I use Adobe Dreamweaver
maybe notepad ++
nope. My teacher said this. She even screen shared it.
visual studio code = good cos u can test it in real time
yea. i use it.
She also said WordPress is bad and should never use it.
right. wordpress = cos u get more satisfaction when u code it and it works
A regular notepad has no code in colors (Syntax highlighting)
but maybe she was thinking “the best way to learn html”
because the less an IDE etc. helps you then you are alone with the text/code
so you learn more and rely on yourself
I’m trying to prevent cheating, but you are kinda supposed to cheat
NO.
I made money using WP EG. How much time did would it take to build a LMS platform using PHP?
I hard code everything…
no.
I did it in 2 hours. I have nothing aganist coding. If you want a good website quick, WP is the best. Key word being quick.
My programs are as messy as me irl. And pretty hard to understand
I KNOW. Crystal is soooooooo hard to understand
Yeah, I have to re-write a whole lotta code that’s messy as heck from when I was newb
