My website pewee.my.id says 403 Forbidden
The website’s configuration prevents you from accessing this page. please help me InfintyFree admin how to fix it.
I tried to do a domain search then came up 403 Forbidden
I did some testing too, and this appears to be a security constraint on our side.
When I try http://pewee.my.id/infinityfree.net , it does work, but when I try http://pewee.my.id/google.com it doesn’t work.
That’s probably because google.com and other popular domains are blocked in URLs to help combat phishing.
If you skip the URL rewriting and do http://pewee.my.id/result.php?domain=google.com it does work, so maybe that’s good enough as a workaround.
I can’t see anything but a directory listing
Well said
